would this work, a Hifonics Brutus bxi 2000w with a 18 inch btl n2? what would the ohms be when i by the btl? it would be dual 1 right?
http://en.wikipedia.org/wiki/Resistor#Series_and_parallel_resistors
simple electronics my friend.
for a single subwoofer with two 2 ohm coils you would wire them in parallel to get 1 ohm load at the amplifier.
again if you want a final 1 ohm load at the amp then you want the dual 2 ohm coil configuration (for 1 subwoofer)
so..... what should i get/do
lmao... Sorry but that was pretty straightforward on the answer but seems like he saw too many words and didn't read past the first 2 lines.
Burn them all in a fire, or do some reading and educate yourself a little bit.
This attitude of not looking for answers is way too common. I find it pretty gratifying if I find an issue I can't work out immediately, do some research and answer my own questions. The knowledged gained from that self education excursion sticks with you a little bit more than someone saying 4 ohms.
Burn.....Burn.....Burn
