Posted May 2, 201213 yr welp finally got my hands on a second aq2200 now the only thing is i hyave no idea how to strap them together!!! lol iv never done any kind of strapping what so ever so help is appreciated!subs are d2's by the way. i have 2 sets of power and grounds in back as well.sexynesssssssss Edited May 2, 201213 yr by Lantz
May 2, 201213 yr For each sub, wire one voice coil's positive to the other voice coil's negative.Wire the two remaining positives to the positive of the master amp.Wire the two remaining negatives to the positive of the slave amp.Wire the speaker terminal grounds of the master to the slave amp. Run your RCA cable to the master amp.Run your bass knob to the master amp.Run a short RCA from the master amp to the slave amp.Flip the Master amp to Master and the Slave amp to Slave.Tune the Master amp.
May 2, 201213 yr This is from the sundown siteThe master amplifier gets the input from the head-unit and a mono RCA from "BR Out" connected. The slave amplifier ONLY gets "BR In" connected from the master. ALL controls are handled on the master, setting anything on the slave is not necessary.This picture should be pretty self explanatory.* The slave takes the "-" connection(s)* The master takes the "+" connection(s)* The "-" terminals of the amps are hooked together.You don't need to use both sets of "+" on the amps. They are there for flexibility. While you should always connect both "-" terminals on the amps together using large wire as general procedure it is not absolutely necessary to use both sets of "+" terminals. They are connected together internally in parallel.
May 2, 201213 yr Author your going to need more then 1 deka and 1 red top.Definitely.i have some batteries in the works
May 2, 201213 yr here is 2 aq2200's cant i just do this? lol looks alot less messyI don't know shit about strapping, but are those amps seriously zip tied together?I know that's not your pic either...I was just wondering.
May 2, 201213 yr Author here is 2 aq2200's cant i just do this? lol looks alot less messyI don't know shit about strapping, but are those amps seriously zip tied together?I know that's not your pic either...I was just wondering.haha yes they are
May 3, 201213 yr here is 2 aq2200's cant i just do this? lol looks alot less messythat's how its done. Only they have one set of speaker wires. You could always look in a owners manual too.
May 3, 201213 yr 1.speaker negative on amp 1 to speaker negative on amp 22.amp 1 positive to sub positive (master)3.amp 2 positive to sub negative (slave)4.all settings on master amp5.all settings on slave amp all the way down6.subwoofer cable to connect the amps (will be a single RCA jack)7.main RCAs into master amp
