Posted May 26, 201214 yr Okay so ive been doing loads of research on parts-express and so forth on finding a sub for a 1974 MGB. I really only want something super small and getting something for better sound quality than just two 6.5's in the doors. Behind the seats is a bit of space but want to keep mostly the stock look. However, there is a compartment where a second battery used to sit that is no longer there and I think I could find a small box in there. I measured the dimensions and can get about .15-.18 cuft gross airspace without making anything look out of the ordinary. I havent found much for the 8 inch woofers or subs that will suffice in that airspace, however there are various ones in the 6.5 woofer range that may work but I was hoping i could get some advice on here for direction. Also I would need a small cheap amp to match with whatever sub I can get in there as well, so information on that would be handy. Another thing I meant to mention is that this is a convertable with a soft top, so im sure that may effect the SQ as well. Your help is much appreciated! thanks!
May 26, 201214 yr By the time you account for the enclosure material and driver displacement (assuming you will have the driver in the enclosure & not inverted) I don't see that airspace feasibly working. Honestly in a convertible I don't see a single 6.5" "subwoofer" having enough displacement to make the endeavor worthwhile. Even a single 8" driver is going to be a questionable improvement.IMO you need to find more space somewhere, maybe find somewhere you can run a larger diameter driver (i.e. a 12") infinite baffle so you don't have to worry about enclosure airspace, just enough room to fit the driver itself and a baffle?
