Not really. If they were going to be from behind then you might as well just have the sub(s) play into the midbass region anyways. Go ahead and bridge the 4chn to the comps smile.png
wouldnt really be way behind me theyd be right behind the seats ill draw up a layout and show you what i want for positioning of everything.
  • Replies 573
  • Views 46.9k
I wouldn't put midbass speakers behind me period. Put the IA components in the kick and install the 8s in the door.
  • 3 weeks later...
gcon and recone should be here within the next 2-3 weeks hopefully i cannot wait to get them in!!
It's a bad idea. You want the drivers placed as wide as possible, and you do not want any of the drivers directly behind you.
You can draw what you like, but I'm positive you won't be happy with the end result if you follow through.
yeah i just decided to do the IA upfront and maybe throw in 1 8'' crecendo in each door. idk yet we will see.
Why would you use a pro audio driver for midbass?
explain to me why i wouldn't want that? i'm not following i think i'd need a bit of a bigger driver because in my van you cant hear barely any midbass upfront its mostly highs and lows. not to much mid
Pro audio mid drivers often sacrifice midbass extension for an increase in overall loudness. In other words they will be loud, but most likely lack the midbass you want.
I'm not saying it's not possible to achieve stellar midbass from pro audio drivers, but in your situation it makes much more sense to use a traditional 8" midbass driver.
so what would you reccomend i look at just like a normal driver but an 8 that would work well as a midbass.
yeah i will be just getting the ia's first but if they aren't putting out what im looking for then i may resort to a driver in my doors.
Personally I think its rather weird to use some driver that needs to be processed in conjunction with a comp set. Either go all active, or use a comp set.
it will probably be all active.
I wouldn't run a comp set active, it can be done but it's pointless in my opinion. There are so many raw drivers out there that would suit active much better.
well then should i run it passive because im getting a comp set
  • 2 weeks later...
First Run of mine in the 1000w class!
Edited by Austin863
Broke my personal record i finally hit the 140.1 i was looking for! i was so damn tickled!
Talk of the show there. One 15 hitting those numbers really made people look.
Awesome Job!
Rumor has it you can sing?
Wow, nice!!! I finally got some bump upgrade in my trunk, two 12's smile.png
My new favourite songs that hit LOOOOOW:
Big K.R.I.T. - My Sub.mp3
Oj Da Juiceman - I Cook ft Gucci Mane (sorry for the quality)
Sha Stimuli ft T-Pain - Everybody Else
-Jamie M.
Edited by toysareforboys
-Jamie M.
Thanks man i'll check them out! biggrin.png Once i get the 2nd gcon in the gwagon. ill make sure i get some demo videos :)
Edited by Austin863
GCON AND RECON HAVE BEEN SHIPPED! :D
NOW i gotta design a ported box anyone know any good calculators i can use?
Your brain....or if that doesn't work the Torres calculator is pretty good. Stefan also has one somewhere.
