For those that have not seen my build log which is kind of old it is located here.
http://www.soundsolu...og/page__st__30
I am still using 4 old school Rockford Fosgate RFR2215 subs.
Since then I decided to do a 4th order wall in my Mountaineer. Just got it in this past weekend and in time for Slamology. Here are a few pictures
Design
It was designed so I can pull it back out and go back to my ported box if I need to
I took this 2x2 support out and used pipe and flanges instead. A lot more strength
It was a tight fit but my friend and I managed to lift this box and get it in there.
Loading wall and port in
Used a pool noodle to seal around the edge of the wall and around the doors. I wish they had gray pool noodles but this is good enough for a temporary fix for the show.
I used some 1/4" Inch steel at every seat bolt to the floor to secure the box down and it is locked in tight.
Edited by Hotdog69
I saw this build on another site. I love the pool noodle idea also.
Pool noodle's are a good quick fix when you need to seal something off. they are only $1.99 a piece and two of them was enough to go around the perimeter of the wall.
They can also be used to seal off trunks
Did a little painting today so it is not just bare wood for the show.
Was at a car audio show in indy tonight got to meet a lot of people and give lots of demos. Josh captured this vid for me. He wanted to see his hat dance in my port.
  • Admin
Old punches!
Old punches!
Old Power DVC's on 2800-3000 Watts (Rockford Fosgate T40001bd @ 2ohm)
I am going to play with the port more this weekend and get it dialed in but I am over 150+ on music now. Here is a couple vids I did when I was only hooked up to the rear batteries one 100ah AGM and a Kentik 25ah cap battery.. I should be over 151 on music after I get done with the port.
Edited by Hotdog69
nice!!
