Posted June 22, 201213 yr Will be installing my second RF T1500bd-cp tuesday and need to know if i should use a spliter on my rca cable or use the pass thru on one of the amps?
June 22, 201213 yr Pass through on the amp. Avoid splitting RCAs if you can.Nothing wrong with a single y-splitter.
June 23, 201213 yr Author Pass through on the amp. Avoid splitting RCAs if you can.Nothing wrong with a single y-splitter.Is one splitter bettern than using pass thru?
June 23, 201213 yr Author Do you mean you want to bridge them to get 3000watts?No im using one amp per sub in chambered box
