So I plan on getting a battery for in the back soon and I was curious as to if it will hurt my battery in the front by getting an AGM for in the back. Also do I have to go with something that is in the range of power my amps are taking or can I go with something along the lines of a XS Power D545?
Roughly with both amps I'll be in the range of over 1800-2200watts rated.
as long as its sealed.. you can run what ever......... some may tell you a acid and a gell wont mix but i dont buy it.
ohhh do the big three first.......
I've already done the big 3. :)
I personally prefer to run same manufacturer front and rear. Definitely not required.
As far as mixing battery types it isnt recommended by battery manufacturers. I wouldnt agrue.
I also wouldnt use an old battery (3-5 years old) with a new one.
The battery under the hood is maybe 9 months old.
Are Yellow Tops as good as I read or are there better for the same buck?
lots of better batteries for the buck... IMO your paying for the name.....
localy.. i can get brand new 100 AH dekes for 10 bucks for then a 55 AH yellow top brand new..... double the size for 10 bucks more.
How do Kinetik do compared to XS?
