Posted June 25, 201213 yr Hi,Subs are 2 FI ssd 12 D2 BP Power . I know they are recomended for a 1.8 to 2.5cf box, Due to the room available I can only go up to 3.17cf after displacement and bracing with 50sqin of port. tuned to 33.5hz? Do they perform well in smaller than recomended enclosures? will be running about 2.5krms to themThanks Edited June 25, 201213 yr by vypr
June 25, 201213 yr If you don't already have the subs go with a pair of tens. If you already have the subs, then it is what it is. All you can do then is build the box and tell us how you like it. Good luck.
June 25, 201213 yr Author Yea I already got the subs. Its either fi ssd 12's or sundown sa-12's I have both. I hope I do like it
