Posted July 1, 201214 yr I want my subs to face up with the port up like one of my previous boxes. I cant seem to get a lot of input and like Ive said previously the pro designers dotn wanna mess with a camaro enclosure. Assuming ive done my math correctly does this look like a suitable enclosure? I just started using sketchup so I have figured everything out so nothings 45'ed or anything.
July 2, 201214 yr I dont understand what is what on your second sketchWhy is your port on the side in your first sketch? Looks loike it would be easier to build with the port in the middle. A 6" aero port would probably work well if you have the depth.
July 3, 201214 yr Author I dont understand what is what on your second sketchWhy is your port on the side in your first sketch? Looks loike it would be easier to build with the port in the middle. A 6" aero port would probably work well if you have the depth.Its a pretty small box. With the 4 inch centered Im so close to the port I have a little bit of unloading and I cant seem to get enough port area according to the tuning calculator. A 6 inch port would need to be 30 inches long and my box is 14 inches deep. Running off the side shouldnt make to much difference I dont think. It should still be plenty loud off what Im running for daily.
