the havoc does sound very good! maybe I will save up and get a mayhem..I really like the lows though. does the mayhem get down like the sp4?
Edited by Bizzy Beats
  • Replies 62
  • Views 6.4k
  • Notorious97200
    Notorious97200
    Turn the gain down a bit. check your box for any leak. You have that noise on all songs or not ? It could be the records. I had a noise problem on my btl , I thought I had. But it was only on one bad
  • I get so sick of: "make your box smaller and you will have less impedance rise" And "make your box smaller and it will handle more power" If we are going to make those suggestions, please add "but it
  • SP4 would be another good choice. It is not going to be as loud as the Mayhem, but it will handle your amp without any problem and sound a lot like the Havoc. The SP4 models up as a low end monster.
i vote SP4 for sure! the Mayhem will get down also though, but the SP4 would just slap with great sq while doing it IMO
I have two 12'' Mayhem's, and they get down and loud.
The RMS rating has absolutely nothing to do with how much a driver can handle in any particular alignment.
It also has nothing to do with how much power you should have/need.
A little food for thought...
As stated in the post above, we have no clue bc we don't know the alignment that will be used.
oh ok. if I did get a ascendant mayhem 18" and a t2500-1bdcp what enclosure would you recommend?
6.5-7 cuft tuned to 32-33 Hz with 90-110 sqin of port area.
The exact design would come down to the box dimensions.
Edited by BKOLFO4
