Posted July 18, 201213 yr Hey there!I need serious help building a ported box. Ive never had, nor built a ported box and i want to see for myself what the difference is. Ive tried every different box calculator i can find, but im sad to say there a little too complicated for me to understand. Im a rookie when it comes to car audio specs. Im a pro at listening tho lol. I want to learn more, a lot more, but everyone close to me dont want to teach, they want to charge. i could easily build a sealed box, but i really want to port my subs.I have 2 lethal injection 12's. I need 4 cubes, 60 square inches of port and i want it tuned at about 32hz. Space is not an issue. I took the back seat out of my ram. I want the subs on the end, and the port in the center.Any advice, or tips or anything that might be of any help is greatly appreciated. Edited July 18, 201213 yr by Pimp-Juice
July 18, 201213 yr Something like this should work. Throw a little bracing in and you should be set.Get me your dimensions that you would prefer and driver displacement and I can get you a better design.
July 18, 201213 yr Author 30"w 20"h 15-20"dIn all honesty, the only demension i have a prefrence too is height. no higher then 20"Speaker displacement is .13 each.Thank you for the design! knowing the displacement, do you think you can make it have 2 common port walls? Edited July 18, 201213 yr by Pimp-Juice
July 18, 201213 yr Are you looking for information on the why's and how's, or are you just looking for someone to give you deminsions.
July 18, 201213 yr By a copy of Vance's cookbook and learn all the T/S parameters. That will be enough to build damn near any box you want and have a general understanding of why and how.
