Posted August 7, 201213 yr I made a small video on how I cut out the inner circle of a tweeter mounting ring. Hope it helps!http://www.youtube.com/watch?v=SuzzLUbVPKM
August 7, 201213 yr Interesting. I always cut the middle out first, but leave about 1/16" of an inch, then route the outside, and simply pop the inside out with my finger, run sand paper and done.
August 7, 201213 yr Interesting. I always cut the middle out first, but leave about 1/16" of an inch, then route the outside, and simply pop the inside out with my finger, run sand paper and done.Yep, same here.. You lose that same center mounting point and #$^^$#$^#^.. that isn't good, hehe.Also, edouble101.. DAMNIT! Routers always cause me to go near deaf from using them and now they're doing it on a damn video. It never fails....Routers are like bullet tweeters out of control.
August 7, 201213 yr Author Interesting. I always cut the middle out first, but leave about 1/16" of an inch, then route the outside, and simply pop the inside out with my finger, run sand paper and done.Yep, same here.. You lose that same center mounting point and #$^^$#$^#^.. that isn't good, hehe.Also, edouble101.. DAMNIT! Routers always cause me to go near deaf from using them and now they're doing it on a damn video. It never fails....Routers are like bullet tweeters out of control.LOL I wear ear plugs
August 15, 201213 yr Interesting. I always cut the middle out first, but leave about 1/16" of an inch, then route the outside, and simply pop the inside out with my finger, run sand paper and done.Yep, same here.. You lose that same center mounting point and #$^^$#$^#^.. that isn't good, hehe.Also, edouble101.. DAMNIT! Routers always cause me to go near deaf from using them and now they're doing it on a damn video. It never fails....Routers are like bullet tweeters out of control.Ear plugs / muffs and dust collectors save lives
August 15, 201213 yr Interesting. I always cut the middle out first, but leave about 1/16" of an inch, then route the outside, and simply pop the inside out with my finger, run sand paper and done.Was going to post exactly the same, but you beat me to it. WAY easier.Ear plugs / muffs and dust collectors save lives Add respirator to that list. If I'm cutting MDF I always wear plugs, muffs, turn on the vac and wear a respirator.
August 16, 201213 yr Interesting. I always cut the middle out first, but leave about 1/16" of an inch, then route the outside, and simply pop the inside out with my finger, run sand paper and done.Was going to post exactly the same, but you beat me to it. WAY easier.Ear plugs / muffs and dust collectors save lives Add respirator to that list. If I'm cutting MDF I always wear plugs, muffs, turn on the vac and wear a respirator.It's not on my equipment list yet but I bet it also helps.
