August 7, 201213 yr $100-$150 for a recone. I am mobile, what are the death rows rated for? I would talk to IA about enclosure recommendations.
August 7, 201213 yr Author So shipping is probably going to be like $50 each time there and back..fml
August 7, 201213 yr Dual 2ohm? So any amplifier rated for 1000wrms to 1500wrms @ 1ohm. Sundown 1500, IA 20.1, Stetsom V1000.1, or my favorite: the Zed Minotaur.
August 7, 201213 yr Author Alright, well thanks for all your help I will contact IA or try too and hope they can help me out.. and post back what happens and such.
August 7, 201213 yr Author Yeah, they looked fine thats why I think its inside the sub. I compared them to some other subs I had laying around. looked fine and checked the leads also looked fine, so I am guessing something on the inside is messed up =/I am going to try contacting IA and see what they can do for me.If I can get it up and going again I plan on rebuilding my box to a 6ft cu air space and it'll be tuned around 35-37hz I will get the BC2000 amp for it.
August 8, 201213 yr Author they called me back said they'd have a tech guy call me..they never did..so idk
August 8, 201213 yr Take the sub out of the box and post some pics. We will be able to tell you what it wrong. 99.9% sure you need a recone
August 8, 201213 yr Separated VC due to clipping, or thermal failure is my guess. I say this because if your push on it and it works, that means something is disconnected at some point.J
August 8, 201213 yr Author Yeah means I need to send it to ia and see if they will fix it but the guy never called me back like she said he would
August 8, 201213 yr probably got busy & forget to reply u but still they shud have better standards than that thoughi have some experience with DP 18s & imho i wouldn't use less than the 6.5 they recommended these 18s seem to prefer bigger enclosures & u will loose considerable low end with a smaller than recommended box , tune ur enclosure around mid to low 30s
August 17, 201213 yr but honstly as far as amp 20.1 would be a good amp for the death penalty i just wonder how powerful the bc2000
