  • Replies 105
  • Views 10.5k
  • Aaron Clinton
    Aaron Clinton
    Loud is relative to the person and the install. There are a number of factors at play here that effect the output. How much sound is allowed to pass through from the rear into the cabin, what kind o
  • Notorious97200
    Notorious97200
    Maybe you expect too much out of a single sealed 12" ? Some ideas ; Try a ported box. Use aeroports too save space if the trunk is small. Change box position : fire the sub through the rear. more p
  • 1w
Maybe the dust cap is loose? How did you set the gain?
Bass boost is off gain is about 1/2 to 3/4
HOW did you set the gain?
Turned it up about half cause it is at 1 ohm now. I checked with a dmm today and it's at 1 ohm an the reason I can't turn the gain higher is because of this problem.
http://s152.photobucket.com/albums/s167/nstickler91/xcon/ there is the album with the sub out of the box.. when i got the sub freshly shipped. it had the chips in the magnet and the spider was not fully glued as seen in the pictures. i didnt think anything of it think that the sub was brand new and handmade and inspected. but as u can see there is no damage to the sub>
Any support or advice would help. Cause I would love to listen to some bass music already
I see no problem with your spider joint; the chips in the magnet are purely cosmetic, they probably happened during shipping. Your dust cap is loose
See if you can find out where it has come loose
Okay I'll check when I get home. In the video u can see the bubble happen its right above the word Xcon
Wouldn't it be where the bubble occurs?
Not if the Dust Cap is loose.Epoxy works good.
That's what I'm saying it isn't even at rms and it is doing this and I have no clue to what it is.
Pull the sub and shake it and see it there is something loose. I am not sure if they put a boob style cap under the dish cap, but it sure does look like it came loose.
