Posted August 13, 201214 yr Will have the bench seats all the way up. Am lookin for two tens or two twelvea ported not sure if twelves will fit. Look at fi bl alpine type rs or sa. Please help money isnt an issue Edited August 13, 201214 yr by krb1991
August 13, 201214 yr What is your max depth?The sundown Sd series was made for tight locations. There isn't a pole vent so you can damn near put it on the wall.
August 13, 201214 yr Author Sweet what do u recommend? 2 tens or could i fit 12s not sure on the measuremnts just a small single cab with bench seats i could post pics or something im tryin to slam this bitch out lol
August 13, 201214 yr It's best to go with a smaller sub in an optimal enclosure vs trying to squeeze bigger subs into an enclosure too small.From here you need to figure out how much space you have and provide solid measurements. Then you can determine what would best fit your needs. You'd be surprised how much a port eats cubes. The box I'm working on now the port itself is 3 cubes. Not that yours would be that big, just saying.
August 13, 201214 yr Author Oh of course bro im good at the installs and shit but not measuring. Ill look it up online and see how much space a single cab tacoma has. Id have the seats all the way up. Had my friend build me a beast box but i moved so id have to find someone who could do it. Could i just tell u measurements and u help me figure it out? U got a cell?
August 13, 201214 yr Um, no. You have it backwards. UNTIL you have the box mocked up really accurately you shouldn't be shopping for drivers.
August 13, 201214 yr Not a difficult thing to do sir.measuring tapepen/pencilpaperMeasure W/H/Dpost said numbers here.
August 13, 201214 yr Not a difficult thing to do sir.measuring tapepen/pencilpaper Smartphone with notes app.Measure W/H/Dpost said numbers here.Fixed
