Posted August 13, 201214 yr Here are some pictures from my build in the suburban. The box is approximately 20 cu ft tuned to 34 hz. I have a 300 amp Ohio Generator alternator with 2 runs of 2/0 welding wire. The amp is an Audiopipe APK-5500 @1 ohm. I have a Boston Acoustics GT-42 running the selenuim mids and crescendo tweeters.
August 13, 201214 yr Author And I can still carry 2 sheets of plywood inside the truck with the box in!!!!
August 13, 201214 yr So I guess people here complete the build logs for you? If it upset you I can delete, was only a funny.
August 13, 201214 yr So I guess people here complete the build logs for you? If it upset you I can delete, was only a funny.your creepyer then i am on photobucket... i atleast let people continue to thinks safe
August 13, 201214 yr So I guess people here complete the build logs for you? If it upset you I can delete, was only a funny.your creepyer then i am on photobucket... i atleast let people continue to thinks safe lmao
August 13, 201214 yr Popular Post Suburbans make me upset. A vehicle should not have that much space to work with Oddly enough it's just a thing Sen seems to do. He's ghey and creepy. Don't let it bother you.
August 13, 201214 yr So I guess people here complete the build logs for you?Yeah, I guess I miss the humor in it as well.Op nice build log, I remember this setup and the previous one on flspl.
August 13, 201214 yr I wanna see some vids! Love the enclosure. I have a couple of 21's myself and I love them.
August 13, 201214 yr Curious if you've messed with the distance from the rear doors & the box? if you have, what were your experiences? I've been told as little as 4" to 10" or 12".
August 13, 201214 yr Author I got about 16" to the back wall. I've tried moving it back a little and the Db goes down a little. Maybe cause my port is 15" wide, it might want the extra room to breathe
August 14, 201214 yr Author Peerless SLS 6.5' midbass in the front doors. I am still working on getting these to sound right. I have the inner and outer door skin deadened but i still got some air leaks in the actual door panel.
