Posted August 14, 201213 yr Hi guys, I want to share with you my future setup and wanted to know if the stock electrical will be able to handle it: I am brand new at this car audio businessI crescendo 3500D at 2 ohm -- 1900 W continuous power1 FI BTL N2 12 running at 2 ohm1 4 channel JBL 100 W rms each channel4 jbl 6.51 Pioneer 9400Box tuned to 32 Hz (got the cut sheets from BTL forums)I will be doing the Big 3I have a 2004 Accord with stock alternator approx. 100 Amps and yellow top optimaThanks guys
August 14, 201213 yr Suggestion. Don't use a black font. Most of us use a black background. And as for your answer, that is up to you. If you listen to Kenny G all day it'll be fine, but that doesn't mean carte blanche it'll be fine. And no, if you are burping a continuous 1900w while driving down the street it won't even come close.
August 14, 201213 yr Author Sorry about the background. This will be daily option and cooling, volume turned turned up maybe a quarter of the way on the head unit. Ill be using for listening to rap maybe a little bit of rock.I read somewhere that if the electrical of the car is not capable, it may lead to clipping? is that true Edited August 14, 201213 yr by mnapoleon
