August 16, 201213 yr How many dbs out of a 12" dcon using 300rms in a jeep liberty.about a 189, give or take.
August 17, 201213 yr Author Is there a prize for a correct answer? For the Gcon I would say 141.5.No but that it probably going to be close. All measurement taken with a spl labs meter.
August 17, 201213 yr Author Dang for no prize and yes, I should be close (I just love this little pic!!!)
August 29, 201213 yr So if I read the tread correctly a 12 dcon on 300 watts rms clean will do 138db or was that just sarcasm?
August 29, 201213 yr So if I read the tread correctly a 12 dcon on 300 watts rms clean will do 138db or was that just sarcasm?In the OP setup, if he is being honest which I think he is ... Then yea it will do 138... Now for you ... No one will ever know til you do it...
August 30, 201213 yr I understand that i just like that the potential is there im not shooting for 138db just figured id ask because in my inexpierence that seems quite high for a single entry level 12
August 31, 201213 yr Author So if I read the tread correctly a 12 dcon on 300 watts rms clean will do 138db or was that just sarcasm?It will in my jeep liberty with the back seats down sub forward and port up.
September 5, 201213 yr wow i also drive a jeep i drive a 2012 jeep compass and whenver i save up the money ill be getting as 12 dcon and i will most likely be contacting you pro rabbit to see about a quote for a ready cut ported box after hearing about those kind of numbers id like to see what mine will do
