Posted August 21, 201214 yr With my car falling apart and things being broken I'm done with my 18. I currently have the image dynamics 6.5 component set in the front but they wouldn't sound that good without a subwoofer. I can probably get 3-400 for my 18 and the box. With that budget what can I do in the front to make it sound good and still hit decent without a subwoofer. My amp puts 50x4 at 4 ohms, 100x4 at two ohms and 200x2 at 4 ohms.
August 21, 201214 yr Doors deadened?Don't expect any bass from them, but they may pack a little punch of midbass if installed well enough. Edited August 21, 201214 yr by stefanhinote
August 21, 201214 yr Get a 10"?And Rick ninja's the shit out of me lol Edited August 21, 201214 yr by An-i-no
August 21, 201214 yr Author That's on the list, to be included in the budget. Door to plastic door panel is covered by the factory pretty well, just inside the door needs deadened.
August 21, 201214 yr That's on the list, to be included in the budget. Door to plastic door panel is covered by the factory pretty well, just inside the door needs deadened.What about the panel that the driver is mounted on? Does the entire panel have large holes in it?IE: Edited August 21, 201214 yr by stefanhinote
August 21, 201214 yr Author Nope, that is all covered by fords deadener, minus maybe a one inch hole for wires and such. Basically all you see in that picture is covered. I'll see if I can find a picture...
August 21, 201214 yr Author Blurry but you get the idea. Except mine doesn't have holes in the deadener like that one does.
August 21, 201214 yr Well then aside from killing any rattles, and possibly making it quieter, I'm not so sure deadener would drastically improve any midbass, but I would still do it for the first two reasons.
August 21, 201214 yr Author Well then aside from killing any rattles, and possibly making it quieter, I'm not so sure deadener would drastically improve any midbass, but I would still do it for the first two reasons. I have no door rattles, just insane roof and hatch rattles. I could skip deadener for now and just go with fronts and a sub then.
August 21, 201214 yr I have no door rattles, just insane roof and hatch rattles. I could skip deadener for now and just go with fronts and a sub then.That would be a good option. When you deaden you will want to do it right, and I don't think that your budget allows for that now.
