Posted September 13, 201214 yr Hi guys I've been looking around at some mids and highs. I'm thinking about trying to run 2 6.5s an 2 tweeters in each front door of a 03 ford explorer and maybe some coaxials in the rears. My question is what kind of amp should I run a 2 channel or a 4 channel? It's seems the 2 channels are usually quite a bit cheaper. What are advantages of running a 4 channel? Edited September 13, 201214 yr by trpkkd
September 13, 201214 yr Author Depending on how you wire it up if I run all 8 speakers I could wire 4 speakers to 1 channel at 4 ohms and the other 4 speakers to the other channel at 4 ohms.
September 13, 201214 yr Depending on how you wire it up if I run all 8 speakers I could wire 4 speakers to 1 channel at 4 ohms and the other 4 speakers to the other channel at 4 ohms.sounds like a horrible idea... don't do that
September 13, 201214 yr Author I am still learning here but why is this a bad idea as long as I keep it to a 4ohm load everything should be okay right or am I missing something here?
September 13, 201214 yr the audio will sound horrible just randomly plugging them all into the same channels... on top of that you'll risk destroying them too
September 13, 201214 yr If you want any real help you must give us more information. What is your budget, what are your audio goals. There is a wealth of information on this forum, slow down, read the rules, ask good questions. Edited September 13, 201214 yr by SS Teacher
