Hey guys before i get completely torn a new one the dimensions of this sub arent clearly listed on the website. I am working with very marginal clearance and i was hoping someone could help me out her. first off im looking to do 2 SSD10s under the back seat of my truck so space is tight to say the least. Does anyone have a picture of these or could help me with dimensions?
Things that i know, the mounting depth is 6 inches. the only pictures that i saw had the mounting depth closer to 7 inches. When did they redesign this sub?
secondly i know at the widest point the magnet is 7.5 inches in diameter.
Can someone please help me with the dimensions of the magnet. The absolute last thing i want to do is order these and then not have them fit. I absolutely dont have the space right now to build another box for this thing.
honestly anything helps guys.
If you have the outer diameter of both the basket and cone, mounting depth, and volume displacement then what else do you need?
i need the physical dimensions of the magnet, ie the diameter of the magnet at the end and the height between the end of the magnet and the widest point of the magnet.
Good luck.
does anyone have a picture of a new ssd 10 from the side perhaps, if i get a picture i should be able to calculate the rest.
Mounting depth is 6" bro.
Magnet diameter is 190mm and it necks down from there on the backplate, so 190mm is the widest point that is ~1.2" from the bottom of the basket flange (pulling this off the top of my head from memory)
hey Nick do you know what the diameter is at the end of the magnet? I have a box that allows for just over 6 inches of mounting depth but the back of the box is a fiberglass cutout as i am trying to maximize mounting depth
Can someone please confirm the mounting depth on an SSD 10 i am topped off at 6 1/8 inches of mounting depth, the website says it has 6 inches of mounting depth but the only picture i could find shows it at 6 5/8s
