October 21, 201212 yr Author since it calls for up to 1.2 cubic foot the box i was suggesting is 1.3 before driver and port displacement
October 21, 201212 yr Is port area entirely dependent on intended tuning frequency and box volume after displacement?Box volume no.Driver xmax and tuning frequency.
October 21, 201212 yr Author i think the ssd has 20 xmax and i want about 33 or 34 hz. how much port area do i need? i wouldnt think much for such a small box
October 21, 201212 yr Author i downloaded the torres box tuning calculator and it gives all the cut pieces you need and everything put it has it where you put in for slot ports. if anyone can help me out and give me the rough dimensions i need to put in to the port pieces i can get everything cut and put together i just dont know about getting the port dimensions right
October 21, 201212 yr Author im gonna go with the ssd , 10 or 12 most likely the 12. i think aero port because i think i would be able to do that better because i dont have any experience with a slot port
October 22, 201212 yr I verified the 20mm xmax.For 33hz you would need around 35 sq inches.A 4" port is 12.5 sq inches lolYou can get away with a little smaller on an aeroport but not THAT much.
October 23, 201212 yr Author i thought you needed 12 to 16 inches of port area per square foot. how would i need 35 square inches for such a small box?
October 23, 201212 yr i thought you needed 12 to 16 inches of port area per square foot. how would i need 35 square inches for such a small box?Box volume has nothing to do with port area.
October 23, 201212 yr Author alright well now im completely confused. do i need like 2 4" aero ports firing up to make more port area?
October 23, 201212 yr Two fours would work if you can get the required length. Are you worried about building a slot port or designing it?
October 23, 201212 yr Author ive got a family member with a shop with a table saw and all the tools in his shop who i can get to help me with it. the designs and dimensions are the things killing me. i am confident in taking my time and constructing the box right but like you said i cant get the designs i need
October 23, 201212 yr Author ill be moving the passenger seat up a little when i dont have anyone in there but want my seat leaned back on the box so i would need the port firing up or out the side. thats why i thought the aero is the easiest way for me to go
October 23, 201212 yr Author i guess ill just have to make the depth a little steeper to make sure it fits
October 23, 201212 yr 2 4" ports for a single 10 (or 12) ? Wow !It's what I had for my Xcon 15" ! And I loved it.Good luck with your build OP.
October 23, 201212 yr Author its for a single 12. i have the cd player and amp ordered. going to be putting those in friday and picked up stuff to make the box. just have to order the sub now. probably going to go ahead and do the box to make sure i get it right before the subs gets here so i can just wire it up and try it when it gets here
October 23, 201212 yr I would not use the gcon for numerous reasons. The monting depth is 6.5" and that does not include clearence for the pole vent (add an extra 2-3"). Using 0.75" MDF for enclsoure construction you will not enough depth with you 8" max od measurement.The Sundown SD-2 10" is designed for your application. Mounting depth is 4.75" and it does not have a pole vent. You can literally mount the driver against the back wall of the enclsoure without affecting driver performance. Also, it is an excellent driver for use in a small sealed enlcosure. Smaller enclsoure equals more leg room, perfect for behind the seat mounting. You can buy it here for $159.99 shipped.This is incorrect. The GCON does not have a pole vent. It has a machined cooling plug. It does not need any space behind the magnet. I would recommend the GCON and the Boston GT2125 to you OP.
October 23, 201212 yr Author i would like to try it but im going with a single 12 and the gcon's box would have to be a little bigger than i have room for
