Posted October 24, 201212 yr I recently purchased 2 Q15's and I'm going to have them in a custom made sealed box in the back of my car.I don't know what a good amp would be for them, so I'm looking for suggestions.Thanks.Specs from my order:- 2x Q15s- Dual 2 Ohm- Cooling: Yes- P Chamfer: Yes- High QTS: Yes- Spider: Yes- I Heat Ring: Yes- Internal Lead: Yes- Rms: 1500W
October 24, 201212 yr Author I wasn't 100% on the factors for deciding 1 or 2 ohm so I just picked 2. Does it make a big difference? Sorry, I'm new to this.
October 24, 201212 yr you will need an amp that puts out desired watts at 2 ohm. 2 dual 4's could have been wired down to 1 ohm which would have been a little easier. now finding an amp that does the desired wattage at 2 ohm will be a little harder/more expensive
October 24, 201212 yr The power you will likely want will be much cheaper at 1 ohm. You should get the D1's. What is your budget for an amp?
October 24, 201212 yr Well assuming you don't want to spend a "shyt-ton" of money on this amp to power at 2ohms then don't look to feed those subs RMS like most newcomers would do....
October 24, 201212 yr Author The power you will likely want will be much cheaper at 1 ohm. You should get the D1's. What is your budget for an amp?I put my order in 5 days ago so I don't know if it's too late to change, or if they even do changes once the orde is placed.My budget is flexible to really whatever is the better option. I wouldn't want to go over $600. Edited October 24, 201212 yr by fireeater235
October 24, 201212 yr The power you will likely want will be much cheaper at 1 ohm. You should get the D1's. What is your budget for an amp?I put my order in 5 days ago so I don't know if it's too late to change, or if they even do changes once the orde is placed.My budget is flexible to really whatever is the better option. I wouldn't want to go over $800.What electrical upgrades have you done? Either way I'd email sales 'at" ficaraudio.com and chabge it to dual 1's.
October 24, 201212 yr Author What electrical upgrades have you done? Either way I'd email sales 'at" ficaraudio.com and chabge it to dual 1's.Just sent an email, hopefully it's not too late. No upgrades yet, my car is still stock and I'm just getting all of the audio components first.It sounds like you haven't done enough research to be ordering things yet.I'm trying my best, just a bit hard to find some answers/good help from people.
October 24, 201212 yr What electrical upgrades have you done? Either way I'd email sales 'at" ficaraudio.com and chabge it to dual 1's.Just sent an email, hopefully it's not too late. No upgrades yet, my car is still stock and I'm just getting all of the audio components first.It sounds like you haven't done enough research to be ordering things yet.I'm trying my best, just a bit hard to find some answers/good help from people.The people here on SSA are more than willing to help, myself included. I'd hate for you to spend a bunch of money and not have what you need/want.
October 24, 201212 yr So you don't have to go crazy on electrical I would grab a Crescendo bc2000 from here on the SSA store. It will be plenty for the subs and you could probably get by with just one extra large battery for the rear. You get up into 3k + you will need a new alt. Focus on a good enclosure. Edited October 24, 201212 yr by swift
October 24, 201212 yr Author So you don't have to go crazy on electrical I would grab a Crescendo bc2000 from here on the SSA store. It will be plenty for the subs and you could probably get by with just one extra large battery for the rear. You get up into 3k + you will need a new alt. Focus on a good enclosure.Yeah that seems about right, not 100% on if I'll get a new alt/battery or both.I'll be making my own enclosure with about 2.4 cuft per speaker. Thanks for the help.
February 7, 201312 yr You could still run @ a .5 ohm load. A Mmats M3000.05d or m2000.05d would be great amps to look into for this setup. Keep in mind that running @ .05 ohm load for daily is not recommended, but these amps are made to perform at these lower ohm loads.
February 7, 201312 yr You could still run @ a .5 ohm load. A Mmats M3000.05d or m2000.05d would be great amps to look into for this setup. Keep in mind that running @ .05 ohm load for daily is not recommended, but these amps are made to perform at these lower ohm loads.Resurrection!!!!lol
