Posted October 25, 201214 yr None on the lights inside truck work now and cd player wont turn on.. Should i run a wire from bat the the yellow wire as to get the cd player to work and.bb i think lights i just need new fuses correct?
October 26, 201214 yr If you hooked it up wrong then yes more than likely blew the fuse.A lot of toyotas run the head unit power thru the dome fuse. Not sure if that is the case with yours but since all your interior lights are out I would venture to say it is.Yes you can run the yellow batt wire straight to the battery. Be sure you use an inline fuse.Or.... You can replace the blown fuse and hook it up the right way and be done.
October 26, 201214 yr If the done fuse is blown and nothing else is done except run a wire to the battery I gaurantee the car is going to burn to the ground.
