Just waiting on getting my two 15" icons and, since I have nothing better to do I was wondering if there was any box type or orientation you'd like to see me try in my 2004 Impala. I'm going to try a ton of different boxes and orientations with a lot of testing to see what works out best in my application and I wanted to have some fun with it. I'm NOT doing a wall, but ill be pretty open to anything else you'd like to see me try. I might actually end up using your idea if it works out the best!
-Mike
  • Popular Post
Boobs!
I'd like to see the enclosure port through the rear deck. Will eventually upgrade and wondering what to do with my coupe, never had a trunk car before and disappointed with sub output compared to a hatchback. Be sure to post pics.
Looking forward to the build! I just put two 15" SSA Icons In my Dakota, box is 7.2 cubic feet tuned to 32hz via a 5x20.25" slot port if I remember right. Kills the lows and has serious punch on rock etc. Got Ram Designs to Design it.
4th order built in trunk.
This^^
I'd just run em free air and hook a 4th order crossover to em.
I may try a single 15 4th order in a friends trunk. 3 cubes sealed and 6-9 ported section. If I do I'll let u know how it turns out.
Seriously bad idea. Stop reading what morons do and copying them. Ratiometric boxes are a joke.
:woot:
Hah. M5 don't worry man, I was only seriously looking at making some 4th order ported boxes. I might try my best to make a 4th order bp just for kicks since I have never done one before but I doubt it will come out well at all..
Simple ported box, 8 - 10" aero with a few different port / sub orientations. Also going to fool around with the tuning a whole lot. Probably from 26-38hz.
Remove your back window and run them free air where the window was.
Tempting...
  • 3 weeks later...
I would like to see two 15s in a trunk in ANY quarter wave enclosure (tapered horn, transmission line, or expanding horn). A tapered horn would be the most likely candidate due to being the smallest of the three. GL ;)
