Posted November 15, 201213 yr guess i am looking to do a 1.5 tuned to 34 hz with the sub pointing up. I have a 4" aero port that i would like to use. i would like to keep the depth at about 15" if possible.any help would be great.
November 15, 201213 yr Author O and i want to be loud so let me know what to do but i prefer aero port since it is easier for me.
November 15, 201213 yr Um, I'm pretty sure that everyone tried to explain to you what you needed to do in your other thread, and it sure wasn't continuing on with the smallest possible enclosure and minimal port area as you were already trying to do. A larger enclosure, with more port area is what you need to do. Getting a larger amp wasn't going to help, and neither is trying to go with this plan.I really don't want to sound like a prick, but dude we gave you the info you needed in your other thread.
November 15, 201213 yr Author Um, I'm pretty sure that everyone tried to explain to you what you needed to do in your other thread, and it sure wasn't continuing on with the smallest possible enclosure and minimal port area as you were already trying to do. A larger enclosure, with more port area is what you need to do. Getting a larger amp wasn't going to help, and neither is trying to go with this plan.I really don't want to sound like a prick, but dude we gave you the info you needed in your other thread.Well i cant build a slot port box just cant seem to make them air tight. I just emailed a box builder that has built a box for me before so i will see what he comes up with.
