Posted March 27, 200619 yr i have one question : how long is the voice coil on the rl-i 10 ? i managed to find on the internet a scaled 'technical' drawing and by my measurements, it's 45mm long. someone on a diffrent forum asked about the coil length and i want to give him a right answer Edited March 27, 200619 yr by Adrian_D
March 30, 200619 yr Author just arguing with someone on a diffrent forum...he said that the coil should be atleast 50mm long with 20mm linear xmax.honestly, i don't give a dang Edited March 30, 200619 yr by Adrian_D
March 31, 200619 yr That 's a very debatable matter, sounds like the other guy's definition of xmax is , coil length minus gap height divided by two equals xmax. Well that only works for one motor topology, long coil with short gap height. I believe the rl-i10 uses TC Sounds TC2+ motor, which is of the long coil / short gap height design. However TC does not measure xmax by that formula, their definition is 70% of BL (which in my mind is the only reasonable way to measure xmax). It would seem to me that using that method of xmax measurement could require a coil quite a bit longer than 50mmjust my $.02 Edited March 31, 200619 yr by neal00
March 31, 200619 yr Author i said that coil length is affected by design, but he said that it's not. that guy is really ignorant. he went to the tricky part : Bl varies across the stroke. sorry dude, LMT fixed that i never thought about that measuring method. thanks neal
