Posted November 24, 201213 yr hello all i guess ill start with a list of the stuff thats going in to the car and on with the pics!!first build log so dont hassle me to bad:lol:charging system consists of : 320 mechman alt , 2 runs of 2/0, one run of 1/0 scosche ofc, dual front and rear frame grounds, xs power d3100, spp2250amp is an opti drive 7ksubs are fi reconed zconson to PIKKSthe altold subsradiogot some new drills the start of a stripper polethe ampthe batteries need to clean up wires and on to the wall tool maker made this up for me Edited November 24, 201213 yr by lilsoccersully
November 24, 201213 yr shit looks fucking tough!! what amp is that next to the 7K? you had the 12 inch z's working hard before right? what are the new subs... sorry if i missed it
November 24, 201213 yr Author shit looks pucking tough!!what amp is that next to the 7K?you had the 12 inch z's working hard before right?what are the new subs... sorry if i missed itthanks! first time acutally building something that is going to stay longer then a few weeks that is a addictive audio 500.1 i had a buddy drop it off for repair and i had just received mine of **** and all the inputs looked to be in the same spot same boards cheaper internals ..the new subs are going to be the same motors just reconed to 18s by fi thank go there local to me yeah they were on a a pair of bb2400.1 strapped at 1, a nendo 5500 at .25, a maxximus 10k 7 k clamped, and finally a pair of audio pipes minis clipped to hell burnt a tinsel lead.. lolheres a vid of when the 12s were in ---> http://www.youtube.com/watch?v=oDYK8lqBR4o Edited November 24, 201213 yr by lilsoccersully
November 24, 201213 yr Nice start! More info on the stripper pole. Is it welded in?Do u plan on metering?What are you tuning to?
November 25, 201213 yr Author Nice start! More info on the stripper pole. Is it welded in?Do u plan on metering?What are you tuning to?the stripper pole is a inch and a half i believe ? might have to double check on that its welded with a plate that is attached to the center of the box and the floor with bolts and pl also the top is welded to a plate then fiber glassed to the roof and the pole also yes i plan on metering as soon as fi gets done with the recones theres a show at the speed way "import face off" this Sunday coming up so we will see how it does and as for the port the comp one is going to be 37 daily 31
November 25, 201213 yr Author got the sides and joints glassed in http://i934.photobucket.com/albums/ad189/lilsoccersully/IMG_20121124_211757.jpg[/img
November 25, 201213 yr if you plan to meter in usaci you will need to put your headliner back in.. other wise, it will throw you into a pro class. you cant have a wood headliner. unless you want to be in pro.... should be nasty. i would love to see numbers.
November 25, 201213 yr Author if you plan to meter in usaci you will need to put your headliner back in.. other wise, it will throw you into a pro class. you cant have a wood headliner. unless you want to be in pro.... should be nasty. i would love to see numbers.That's not good to hear lol the head liner is in the trash got messed up from the last build that I did would I be able to carpet and foam pad the wood and consider it headliner ? Edited November 25, 201213 yr by lilsoccersully
November 25, 201213 yr Author Build log is looking tough man. That Opti 7k looks the shit too.Thanks hopefully it preformes like everyone claims and looks
November 29, 201213 yr Author First coat down wet sanding ahead of me and a couple more coats Little heater should help coat times
November 29, 201213 yr Author Looking good!Thanks I have a couple of days to finish that is if my recones ever get done on time
November 29, 201213 yr Author Do you need to install the port?Nope its tuned to around 80 hz I Kidd yeah I still have to Install it and paint it also that's my next step then test it and see how it does Haha I hope so.
November 29, 201213 yr Do you need to install the port?Nope its tuned to around 80 hz I Kidd yeah I still have to Install it and paint it also that's my next step then test it and see how it doesHaha I hope so.I have seen some burp cars that have a port that looks like that. I didn't know what your plans were.
November 30, 201213 yr Author Wet sanded the from inside and roof Amp mounted Another layer before waxOutside view Edited November 30, 201213 yr by lilsoccersully
November 30, 201213 yr I have the Makita 18v lithium cordless set as well, been using it for a year and I love it so far. It should serve you very well.
November 30, 201213 yr Can you show us the car ?Is it really a BMW ?Nice work, nice equipment, but what about the highs & mids ?thanks for sharing !
December 4, 201213 yr Author ok so results from the show in the 158.7 @ 51hz in the kick door open although my music score whent down at the show at 152 vid coming soon like its uploading soon!!
