Posted November 25, 201213 yr Just a little build log of what I have done so far, with crappy cell phone pictures.The TruckMaking holes to run the wire.Installed grommets for two runs of 1/0, one positive and one negative.Mocked up false floor.Wrapped up and wired up distro blocks.Wired up the stereoWired up and mounted the amp.finished as it sits now.Still have some ideas to remount the amp/amps.When it gets warmer out Ill be laying down some fiberglass for kickpods and working on mounting tweeters somewhere.
November 25, 201213 yr Hi Bromo haven't seen you in a while.Looks really clean! What are the drivers you have for the front currently?
November 25, 201213 yr Author Hi Bromo haven't seen you in a while.Looks really clean! What are the drivers you have for the front currently?I've been around, been pretty busy with work so I've been lurking.Right now they are stock, I have some AA carbon fiber mids and Seas neo textiles to use but its a little cold to try and fiberglass.Looking awesome! How are you liking the gcon?Its great, its really really close to the old ICON which is great.
