Posted December 23, 201212 yr Would like to buy a big extra high current battery for car audio, looking for 125ah or more for a low budget, looking to spend less than US$ 250 , thank you.
December 23, 201212 yr kinetik makes a 2400 128 ah battery for 300$ its on sonic electronix if that helps any but ill look into it for you and let you know if i find anything more sutiable
December 23, 201212 yr what kind of wattage are you running and do you have a big enough alternator to power both batteries
December 30, 201212 yr dont run kinetik horrible batteries.are you in florida? you can get used batts for super cheap.
December 30, 201212 yr dont run kinetik horrible batteries.Seriously?They're very over rated, and I've seen first them fail, epically. I'm talking swelling to where you can see the individual cells, the sides going out over an inch. That being said, I'm not sure what happened with the amp deal, but if you need help finding batts, I can help point you in the right direction, you have my number.
December 30, 201212 yr Author really, kinetiks are like that?And how good is that Sears Diehard Platinum?
January 2, 201312 yr Author How do I know what battery is better? looking at what specific specifications?
January 3, 201312 yr Well working at Oriellys i would have to say get one of their semi AGM batteries.I think they are like 110$ a pieceI have 4 of them in my truckhttp://www.oreillyauto.com/site/c/detail/SSB5/315T/N2493.oap?ck=Search_N2493_SSB_-1_1888&mn=Super+Start%28R%29&mc=SSB&pt=N2493&ppt=C2389
January 4, 201312 yr Author How do I know what battery is better and more powerful? looking at what specific specifications?
January 4, 201312 yr CA or CCA (cranking amps or cold cranking amps) would be what to look at for burps or competition style use, AH (amp hours) would be better for long draw on music and demoing. A combination of both would be best. Just look at the biggest AGM battery you can afford and fit really.
