  • Replies 78.9k
  • Views 4.3m
  • jonbearsmt
    jonbearsmt
No enclosure. If I am putting in that much work an 8" SLS will go in. I know which are going in, just took that pic for hdox and thought I would throw it up here.
The U's are beautiful. The Dayton's definitely the turd of the bunch
Want to lower the rear another .5" or so...but my suspension links are JB Welded since they wouldn't thread on. Looks like a rather standard link end, but I can't find them. Any thoughts on where I could?
Little plastic pieces on the end of the rod
http://www.rockauto.com/catalog/moreinfo.php?pk=3903627&cc=2002721
http://www.amazon.com/Delphi-ER10016-Vehicle-Turn-Sensor/dp/B0089RSXR8/ref=sr_1_1?ie=UTF8&qid=1404916243&sr=8-1&keywords=DELPHI+ER10016
If you can, take one to your local Fastenal, then get specs and order through McMaster Carr.
Are you bagged at all four or just the rear?
You can also control manually via toggle switch.
Bagged at all 4, but the kit I have picks a ride height and the designer recommends shortening that link a bit.
Hmm, what goes in the truck?
Going to pair them with the Scan D2904's in my basement. Ought to make the installation portion easy which is important to me atm.
if you're building an enclosure, the Revs are the winner.
Yummy, yummy! I would do the Revs in a heartbeat if I could mount them on axis. Would be a coin toss in a factory location.
I have broken brake hard lines when 4-wheeling. A manual trans come in nice for getting off the hill after that one.
I have replaced quite a few brake lines that corroded through. Last ones where on a 96 Caddy from back east. Every line in the car was spraying.
Those are 7's...
Seriously, wtf. I've downloaded a boat load of music players and can't find ONE that does something REALLY simple that I want.
I will make playlists based on Genre. Then I want to listen to them. When a song comes on I want to remove I want to flag it as "bad" or whatever and have it removed from the playlist.
The lists I already have (and cross Genre's actually) but I just want to remove songs from them. I'd prefer to do it in car and then share the lists across my house and such. Would allow easy exports to smaller devices that can't carry 1tb of music too by exporting appropriate playlists. My music is uber clean and sorted damnit, I just want nice control in the car.
And what is with all the media players and their teeny fonts. I dont' need to see 200 songs on one page, I can fucking scroll.
