  • Replies 78.9k
  • Views 3.6m
  • jonbearsmt
    jonbearsmt
All steaks should be thin Mike.
A little bit less than the diameter of my cock is perfect.
So about 5 inches
Tuna can for sure.
I'm the chicken of the sea of the bedroom.
Mike - if your grill was on high for an hour and that is the finish you got on the steaks your grill is pointless.  Your shrimp look like they soaked in cold oil instead of frying as well.  You need heat.  WAY MORE heat.
Weber Spirit two burner grill. I was going to home brew a wood chip holder and some sort of heat diffuser
Fuck that, just do the ribs at home first.  Restaurants smoke fresh ones then freeze them and grill to serve ALL the time.  Won't be quite as good as never frozen (assuming you aren't already buying frozen ribs as that would of course defeat any difference) but will still get the smoke you want on the smoker you have and will make your cook time minutes in comparison.
Just presmoke to still heavy chew required to separate from the bone, but not so bad you can rip them apart.  Tips should be well exposed but not fall apart even if you only grab 2 bones with the tongs.  Defrost the day before and grill like you would a cut up chicken.
