Obama is for everyone. He is doing stuff to help the middle class more ,
but if you really think about it its an advantage on the upper class as
well because the middle class will spend more, making more profit for
the upper..Yes , we our economy has been bad but it takes more than 8
years to better the United States after Bush ruined it. He does say
what he's going to do & has been sticking to it this whole
presidential election. I do also think Obama can atleast relate to the
common man and understand the hardships the average American must
overcome rather than living the cushioned life. This year is almost a
lose/lose in many areas, but Obama is the righteous choice for this
government.
Pass the crack pipe baby girl.
  • Replies 78.9k
  • Views 3.9m
  • jonbearsmt
    jonbearsmt
government.
This may be the dumbest shit I have ever read on here. Seriously
from the strange formatting it looks like it was copy and paste into the reply box. noob troll
2 minidsp 2x4's on the way! was going to wait a bit longer to order them but i'm itching for a new project. stephan or sean, what plugin do i need? (mind sending it to me so i can try it out on my macbook. the os is out of date so I'd like to see if it will still work)
i was also thinking the MS8 because it should be the most simple to set up.. . seems like the mic feedback system is simple.  and would work well.
I was not impressed with the MS8. Only way I could get it to approach decent sound was by disabling the auto tune (also happens to remove T/A, which sucks), and spending six months tweaking the settings. Ordered a minidsp, used the xo settings from the MS8 as a starting point, and after an hour everything sounded better--zero compromise.
The auto tune on the MS8 in my install made the sound sterile, lifeless, and robbed me of my midbass. Tuning was an absolute bitching having to run through the setup wizard everytime you wanted to change a filter setting.
Just my two cents.
ever try the REW auto tune to compare against the ms8 auto tune? i'm guessing both are equally shit
eh, i smell 3k post. dont mind me
thermaltake-level-10-mouse-bmw-designwor
bmw designed a mouse
good night
Depends on what you need for crossovers.
why the testing in a hemi-anechoic room?
For testing to make sure it is completely silent, no button clicks or movement noise
Come on next paycheck, I need some off-road tires, road tires don't feel confident at all on dirt and gravel sad.png
What do you mean by gravel & dirt?
Generally speaking completely smooth tires have the most traction. Completely diffeent than cars. Although when you have really loose shit that changes.
The trails here are in the woods and on fields. Dirt roads, lose dirt over solid dirt, lose gravel, even sand at some point. I'd say 50% of the surfaces are like in Seth's pictures. I wouldn't call the surfaces really lose.
With my current tires, on off-camber sections I'm sliding down, downhill I don't have enough braking confidence (kool stops are the bomb) and uphill I have to stay seated for grip and on corners they don't give me any sense of security.
Last week I ran into some muddy climbs and the rear slick was worthless. In the winter it was enough to get me by on straights but worthless on any sort of slope.
I'm looking at this:
2.1 tire should also be a bit softer on the bumps than a 1.75
Expy is having a little issue accelerating, most noticable from a stop. Then it picks up as it changes gears... then looses it at 50 or so. I thought it might be from the seafoam but I am an 1/8 of a tank into fresh gas and it's still a little goofy. It is also only noticeable after it has warmed up. When cold it seams to be perfect.
There is a really strong fluttering sound that I thought might be a hole in the exhaust but I cannot find it.
I think I have a code. I will swing by an auto parts place and have them check it.
Not even a little stutter though.
Edited by dem beats
Sunday come way too quickly.J
Ahh, I didn't know you changed your name to Sunday. Cute.
I didn't even see that turn. Very well played. Gave me a good laugh this morning. ALMOST as good a laugh as the 'Obama is god' rant this kid made.
J
Just sell that damn money pit.
Time pit maybe. I have put less than 8000 into it including purchase price over as many years.....
If I don't count rotors and brakes as consumables etc it would be 7500 or so.
