  • Replies 78.9k
  • Views 3.6m
  • jonbearsmt
    jonbearsmt
Then huff the fumes?
Ethanol vapor will Fuck you up.
Take a 2L bottle and put a bit of everclear in the bottom (small amount). Fit a cork into the top and run your air compressor into the cork into the bottle. Turn the pump on. Let it fill as much as possible and pull out the cork. The drop in air pressure vaporizes the everclear, breathe deep. Ahh the shit you learn in the military....
Does that just feel like a normal "drunk" or what?
Another good option are vodka colonics.
Butt hole boozin is another way to conserve your stash. Wasted on a shot or 2.
I did this once on a dare and this is VERY true. Keep a tampon in its applicator and soak it in a shot, then up she goes. You get literally hammered from a couple shots. One shot and you're pretty much good.
Explains everything.
Only a little disturbing, eh?
been awhile..  120 something pages behind on the hop.. ugh
got my mini dps installed and started my nexus 7 dash install. i'll have to get some pics later
Jesus.....junk yard time?
Fuck that. I will never put a used bearing in anything I own.
Speaking of bearings. I dropped off the company vehicle a 2010 Ranger for service and it needed new pinion boots, rear axle seals were leaking which were both under watrentee. Front hubs were loose (truck had slight vibration even when new). They recommend repacking bearings and tightening, why in the world would you not spend an extra 60 bucks and just change both bearings while you got the hub apart?
man im shitting bricks i hope labcorp hurrys so i can either be happy or reap what i sewed
Baby or drugs?
J
Baby or drugs?
J
UA for a new job hopefully
So whats going on Jon? You seemed a bit worried. Hope all is well!
Edit: I would have read further. Hope you get the job!
Edited by ChILL
Baby or drugs?
J
I didn't know UA needed tow truck drivers
The entire world needs tow truck drivers. You have no idea what it takes to do that job. In fact, few people do. I guarantee you if you had to do that job for a week, you would think more of a man whom you think merely drives a truck and hooks chains to cars.
so i've installed a pair of fountek fr88ex in my brother's car a few years back. today he has me check them out and i find that the coil locked up one of them. tore it apart and see that the motor shifted
