Still not a good way to purify water. There is a reason why a thump keg is used during distillation. You'd be just as good to boil it.
  • Replies 78.9k
  • Views 3.6m
  • jonbearsmt
    jonbearsmt
Bought GTA V yesterday. Graphics are better and the world is big, but driving is fucking horrible. Why did they decide to change some of the controlls? And WTF is with the aliens? I don't know... at this point I am pretty disappointed.
The alien thing has been just funny to me. I haven't played more than a couple hours. Work is killing me.
it opens up a bit when the heists start. if you're not enjoying some of the side mission stick with the main story line. you can also avoid some driving by calling a taxi.
I thought you could distill anything as long as it isn't corn alcohol.
S3: I've seen ads for home distilling equipment in catalogs
("turn wine into brandy," "make your own essential oils"). Is it
legal to buy and use a still like that?
Under Federal rules administered by TTB, it depends on how you use
the still. You may not produce alcohol with these stills unless you
qualify as a distilled spirits plant (see earlier question). However,
owning a small still and using it for other purposes is allowed. You
should also check with your State and local authorities - their rules
may differ.
A still is defined as apparatus capable of being used to separate
ethyl alcohol from a mixture that contains alcohol. Small stills (with
a cubic distilling capacity of a gallon or less) that are used for
laboratory purposes or for distilling water or other non-alcoholic
materials are exempt from our rules. If you buy a small still and use
it to distill water or extract essential oils by steam or water
extraction methods, you are not subject to TTB requirements. If you
produce essential oils by a solvent method and you get alcohol as a
by-product of your process, we consider that distilling. Even though
you are using and recovering purchased alcohol, you are separating the
alcohol from a mixture -distilling.
http://www.ttb.gov/spirits/faq.shtml#s3
You cannot distill anything that makes alcohol, be it for spirits or for fuel, without permits and licenses and such.
Make alcohol from sugar, legal.
Separate alcohol from water, illegal.
Yeah that makes sense...
My friend car on ADV's the wheels look sick
FYI. Petroleum manufactures add a small percentage of methanol to ethanol to get around ethanol taxes. This is why you cannot drink it.
Fermenting fruits high in pectin produces methanol, but during distillation it's separated, and final product has to be under a certain %.
Yes pectin aka fiber aka celulose aka wood is where methanol comes from.
What other fruits make for tasty spirits? I'm thinking of making apple cider and applejack first. Can plums work, or too tart?
I've made it from just about everything. It'll loose its tartness. Your best bet is to boil whatever you use to increase flavor.
Banana is about the best tasting. People like it more by a long shot.
I did the first heist.
I didn't know about the taxi, thanks.
How do you get off the trolley. I hopped on and it wouldn't let me off.
