I got a Power Acoustik 4000 watt MONO amp for sale. I got this from a friend and have no use for it. Im selling it for $110 shipped. Lemme know if you want it!!! PM ME!
  • 4000W Max Monoblock Class D Amplifier Car Amplifier
  • RMS Power Rating:
    • 4 ohms: 1200 watts x 1 chan.
    • 2 ohms: 1700 watts x 1 chan.
    • 1 ohm: 2200 watts x 1 chan.
    [*]Max power output: 4000 watts x 1 chan.
    [*]Fully regulated PWM power supply
    [*]Wired remote bass level control included
    [*]System distress indicator
    [*]Four way protection circuit
    [*]Adjustable Tuned Bass EQ (0-18 dB Bass Boost)
    [*]Hi-Speed digital circuitry
    [*]Full selectable crossover (HI,Full,Low
    [*]1-Ohm Stable
    [*]Full selectable crossover (HI,Full,Low)
    [*]Die-cast aluminum heat sink designed for massive heat dissipation from three sides of the amplifier
    [*]Heavy duty aluminum alloy heatsink or High-density split-dome convection heat sink for extreme heat dissipation
    [*]Platinum-plated RCA level inputs
    [*]Platinum-plated screw terminals
    [*]Variable low-pass filter (40-200 Hz, 24 dB/octave)
    [*]Variable subsonic filter (20-50 Hz)
    [*]Variable subwoofer EQ @ 45 Hz
    [*]Frequency response: 20-200 Hz
    [*]Signal to Noise Ratio: 100 dB
    [*]Dimensions: 13-3/4"L x 8-1/4"W x 2-1/8"H
Image doesn't work, bad link
  • RMS Power Rating:
    [*]1-Ohm Stable
