Oh, alright i understand it a little better now. My speakers, on certain songs when the volume is up, tend to be fine to a point and then part of the frequency range just drops off significantly, although, at much lower volumes it does not seem to happen. Not sure what would cause that? im also not using compnents.
either installed incorrectly or you're over powering them... or a combination of things.
  • Replies 60
  • Views 6.9k
  • Beaming will occur when the frequency wavelength is less than or equal to the diameter of the cone.   Make sure your units are the same:   wavelength(cm) = 34029 (cm) / frequency (hz), so: Beaming Fre
  • Before even starting with a mid you need to determine potential mounting locations.  EVERYTHING is a compromise, no need to add more by deciding things without the background.   Oh, and give up on kee
  • It's like you didn't even read my posts   When using multiple drivers the center-to-center distance should ideally be no more than one wavelength of the highest frequency played by the drivers.  Or,
Exceeding the driver's abilities and or installation.
Im not sure it seems to only happen on a few songs, maybe 5-10, and i have played at least 500 different songs through them.
what you high pass filter set at?
well whatever might be the problem your speakers are trying to tell  you that something is wrong. you would probably want to look into it or just keep the volume down on those songs.
I havent been able to figure it out, so i have just kept the volume down on those songs.
Could be several things.  Could be those songs are heavily compressed and have little dynamic range, so as you increase the volume you are clipping the amps (inputs, not just outputs) or running into power compression issues on the drivers.
It may be due to the compression and lack of being dynamic. i remember that i looked at a few of the songs in audacity but i do not rememer much of what i saw.
  • 4 weeks later...
  • Admin
Another excellent topic showing why SSA is the forum for audio, period. ;)
And Chill we still don't know your mounting locations. That HAS to be determined before even thinking about driver choice. I assume since you have the Goat now that it all may have changed, but we are waiting hear to help.
