Posted February 27, 201313 yr So no more then an hour ago I had a post about a Focal amp I found on WoofersEtc.com for 200 bucks but then someone recommended an NVX amp. I checked out the website which i'll link below andwas impressed with the gear and information provided. What they had to say about there company and videos I watched I figured they are definitely worth a look. As of now I am looking at Soundqubedfor my amps but I can get NVX amps for a little cheaper and from what I saw they look better. Anyone have experience with this company ?? They formed in 2011 according to the website and the gear looks impressive. I'm even looking at the VCW122 12' dual 2 woofer. Stats look good. FI Q12 is what I'm looking at now. Sound Quality over SPL is my goal for all types of music. So what people think? Soundqubed amps are Q1-1200D + Q4-120https://www.soundqubed.com/ NVX amps are Jad1200.1 + Jad800.4 (prices are cheaper on sonic)http://www.nvx.com/
February 27, 201313 yr that particular nvx amp is a common design used by a number of companies recently. the difference between all of them is probably the components used on the boards. polk http://www.amazon.com/Polk-Audio-4-Channel-Amplifier-PAD4000-4/dp/B006OCBW1Y ppi http://www.onlinecarstereo.com/CarAudio/p_33876_Precision_Power_P9004.aspx?utm_source=google_shopping&utm_medium=Product_Feed&utm_campaign=google_shopping_Price_Comparison&gclid=CLPd0ZaS1rUCFVGf4Aodmz0AhQ soundstream http://www.amazon.com/TN4-900D-Soundstream-4-Channel-Class-Amplifier/dp/B009NLNY14/ref=sr_1_10?s=car&ie=UTF8&qid=1361956285&sr=1-10&keywords=soundstream probably a few more brands like hertz iirc, you can search for a list im sure Edited February 27, 201313 yr by lithium
February 27, 201313 yr you could probably pick one based on aesthetics and expect similar performance.
February 27, 201313 yr I've got a couple of the Polk versions and they are fine. NVX wasn't out when I bought them, but I still probably would have spent the extra $10 each.
February 28, 201313 yr Author would any of you even consider the NVX JAD1200.1 mono amp over the Soundqubed Q1-1200D ?? http://www.nvx.com/amplifiers-1/jad12001.htmlhttp://www.soundqubed.com/Q1-1200D-Amplifier_p_30.html Can't find any CEA-2006 compliant on the Soundqubed but awesome reviews.CEA-2006 compliant on NVX with very interesting promises/stats.both about the same priceboth small companies.
February 28, 201313 yr would any of you even consider the NVX JAD1200.1 mono amp over the Soundqubed Q1-1200D ?? http://www.nvx.com/amplifiers-1/jad12001.htmlhttp://www.soundqubed.com/Q1-1200D-Amplifier_p_30.html Can't find any CEA-2006 compliant on the Soundqubed but awesome reviews.CEA-2006 compliant on NVX with very interesting promises/stats.both about the same priceboth small companies.CEA compliance means nothing. Terrible standard. I wouldn't consider the Soundqubed, but have an amp that has the same board as the NVX. Again personally I'd spend a few bucks more for the PPI/Polk/Hertz version of it.
February 28, 201313 yr the ppi's look better than the nvx and cost about the same. you wont notice a difference in output between the sub amps http://www.onlinecarstereo.com/CarAudio/p_33876_Precision_Power_P9004.aspxhttp://www.onlinecarstereo.com/CarAudio/p_33874_Precision_Power_P10001.aspx Edited February 28, 201313 yr by lithium
February 28, 201313 yr Comment that I was about to post in your locked thread: Either one will do the job, it won't matter if they are underrated.
February 28, 201313 yr The only NVX product I own is a fuse holder and it does the job, I'm thinking of trying their 1/0 wire just to compare to my kicker wire since they seem similar. As ricksi30 posted, you won't notice a difference as far as amps go. I wouldn't hesitate to pick the Fi Q over the NVX sub, just my personal opinion.
