i personaly dont care for them.
 but some people swear by them.
I stay away from those amps, but that is just my personal opinion.
They are sold on the SSA store.
Thank you i must have over looked that... I was just looking in the store area on the products sold here.
They are sold here yes, but i was looking for other opinions... On another note i just did a lot of reading and on random topics and it seems there is a lot of negatives even some coming from you, all in all it seems i will not be making the purchase to this amp.
Look into Crescendo Audio.
Will do that. Just what caught my eye on the stetsom amp was that it puts out a lot of power at low voltage and it intrigued me that the amp had 2 options 1ohm or 2ohm
I still have my 7kd.
Puts out good power honestly.
However yes the single terminals you have to buy the distro-block terminal
Now i ran it at .5ohms and it caught on fire, not the amps fault, my fault for reading what other ppl did instead of listening to manufacturer.
I got it fix under warranty and it is back in my truck as of now.
They are good amps, just have to follow directions i suppose.
The fan is a bit loud is my only complaint honestly.
They have fallen down in the past on slow customer service, very slow set up when it comes to shipping orders, very convoluted amp repair set up, subject warranty handling, and the durability of the amplifiers have clearly been in question by a number of people for a number of years.  I am not poo pooing on the company, I know they are working on speeding up things.
trong>
True and i understand just dont want to spend money on a gamble like armykyle is saying... I got the funds ready to do my c pillar wall just if i don't have to spend 1200 to get the power i need from an amp then why should i... The specs do look good though and durability is going to be a high factor in this as my amps may be secured on or close range of the wall...
Wouldn't touch one honestly. Check out other options like Sundown, and Crescendo which are also sold in the SSA store.
Im looking for something around 7k at 1.34ohms.... I say 1.34 ohms because thats most likely how im going to wire my subs, that or 3ohms
1.34 ohms?  I have never seen a sub with an impedance 1.34
He might be running 3 dual 2 ohm subs to get that independence.
3 dual 2 ohm
dont say impedance because shizzon will get upset and come in and correct you !
What would is there to get corrected about? Kinda curious now
You can still say impedance.
its the same thing in a general sense.
Why do u ask because there both in ohms at the end of the day.
