Posted March 9, 201313 yr The first time i bought trunk audio a bought a 1000W kenwood amp and 2 12" 400W kenwood speakers. and when i connected them in series + to - it was ok bass but when i turned it up past 20 volume the music got louder but the bass got quieter. and when i connected them in parallel it was awesome very loud sound and bass but the amp heated up a lot please recommend me a amp and speakers i should get that will be loud and make by trunk bounce lol Edited March 9, 201313 yr by vadimz
March 9, 201313 yr Author like even if i was gonna buy from CL or eBay... How much watt amp should i get? dual Chanel or single? and what kind of 12" subs should i get? and how much watt should they be. something that will be good for loud bass performance.
March 9, 201313 yr $500-$600 will not get you super loud bass, but it could get you started on your way. Do some research and go from there.
March 9, 201313 yr Author $500-$600 will not get you super loud bass, but it could get you started on your way. Do some research and go from there.ok but if i keep my current speakers what amp should i get? im thinking a dual Chanel how much watt should each Chanel have for 4ohm 400 watt spekers
March 9, 201313 yr Author Just get an 800 watt mono block amp.i found one i think will work great http://www.bestbuy.com/site/Boss+-+CHAOS+EXXTREME+CX1250+Car+Amplifier+-+2+x+380+W+%40+4+Ohm+-+2+x+1.25+kW+%40+2+Ohm+-+2500+W+PMPO+-+2+Channel+-+Class+AB/3272202.p?id=1218390973354&skuId=3272202&st=700w%20two%20channel%204%20ohm%20amp&cp=2&lp=5
March 9, 201313 yr Just get an 800 watt mono block amp.i found one i think will work great http://www.bestbuy.com/site/Boss+-+CHAOS+EXXTREME+CX1250+Car+Amplifier+-+2+x+380+W+%40+4+Ohm+-+2+x+1.25+kW+%40+2+Ohm+-+2500+W+PMPO+-+2+Channel+-+Class+AB/3272202.p?id=1218390973354&skuId=3272202&st=700w%20two%20channel%204%20ohm%20amp&cp=2&lp=5NO!
March 9, 201313 yr I'd suggest something along the lines of 2 sundown E series 12s with a hifonics amp since you are on a budget. It's not going to be a crazy loud system but should definitely bump! Just make sure you have a good built box.
March 9, 201313 yr Or you can splurge and treat yourself to a couple of DCONS But like bassink said, the enclosure will the most important part
