Posted March 18, 201312 yr So i'm in the middle of building my box, i used torres tuning calculator along with sketchup to design the box, i'm 98% done with it and realized that my Hz may change due to the fact i'm using a center divider. currently my specs are, 2 12in Fi BL's3/4in MDF Outside MeasurementsHeight-15Width-34Depth-20 Center Divider- 18.5 x 13.5 Inner Port DimensionsHeight-13.5Width-2.5Length-17.75 Those specs give 32Hz overall "if" i use them in Torres Tuning Calculator, now im a little upset cause i think im gonna be starting from scratch again being i added the center divider, if i split the width in half to make up for the center divider i get stuck with 51Hz If i change the width of the port to 1inch ill be at 31.71Hz, "But" with only a 1inch port will i be getting port noise?
March 18, 201312 yr I could've wrongbut your port looks too small in my opinion. Why do you need the divider?
March 18, 201312 yr Author I added the divider cause I have 2 ports one on each side of the box, n just wasn't to sure if it would throw the tuning off being Torres calc. says box to complexed of box n yea its confusing how it all came about
