March 25, 201313 yr Author someone in ur town just won the powerball so go borrow some money and come out and meet us all, hmmm ... wish I knew the person... I'd be their loyal slave.... lol
March 25, 201313 yr someone is my town just won like a mill in the powerball i know the girls brother,.
March 25, 201313 yr Author I wish I would win... been playing for months now... I win some money on scratch offs... so far I am a bit above even from day... haven't played in a week or 2 though.....
March 25, 201313 yr lol.. i been playin it more and more regardless of what the jackpot is. One of these days I'm gonna win the jackpot.....as soon as I start actually playing.
March 25, 201313 yr I'm not reading all the replies. http://www.coilsprings.com/ I was going to them before I flipped my car. Worst case, would have been 280 shipped for the rear. That's completely custom wound with variable density. Most likely would have been 200. They put a lot into their springs. A local guy used them with great results.
March 25, 201313 yr Author I'm not reading all the replies. http://www.coilsprings.com/ I was going to them before I flipped my car. Worst case, would have been 280 shipped for the rear. That's completely custom wound with variable density. Most likely would have been 200. They put a lot into their springs. A local guy used them with great results. Thanks again... I've yet to contact them for a quote... Not looking for anything crazy in weight handling.... so I'll see what route I go...
March 25, 201313 yr I'm not reading all the replies. http://www.coilsprings.com/ I was going to them before I flipped my car. Worst case, would have been 280 shipped for the rear. That's completely custom wound with variable density. Most likely would have been 200. They put a lot into their springs. A local guy used them with great results. Thanks again... I've yet to contact them for a quote... Not looking for anything crazy in weight handling.... so I'll see what route I go... I was on the phone with a tech guy for a good 15min. Basically, 200-1000lbs, they got you covered. I would prefer a factory style spring(linear or progressive) over add on stuff. I was quite impressed in how in depth they went. Good luck man.
March 25, 201313 yr Author Thanks... I found some stuff on rockauto but it's unclear what each model is.... It "seems" that they have a super duty coil that could potentially handle up to 1000lbs.... not sure though... I sent in a comment to them on it...
March 27, 201313 yr not sure how the suspension is on the toyota, has anyone looked up a spacer for the spring by chance? maybe like a leveling kit like the lifted trucks have? if you went air suspension you wouldnt regret it. My s10 is bagged and i love it. only thing i would do different is instead of the 1/2 SMC valves id switch it all out for a accuair setup
March 27, 201313 yr Author not sure how the suspension is on the toyota, has anyone looked up a spacer for the spring by chance? maybe like a leveling kit like the lifted trucks have? if you went air suspension you wouldnt regret it. My s10 is bagged and i love it. only thing i would do different is instead of the 1/2 SMC valves id switch it all out for a accuair setupyea.... too much initial custom work which would involve finding a mechanic to do that work, more monies..... and the up-keep although mentioned as simple might cost me troubles in the end
March 27, 201313 yr My vote is to replace w/ stock parts and you will notice a change. The way you are describing it to me sounds like it is just worn out. How many miles are on the car?
March 27, 201313 yr Author My vote is to replace w/ stock parts and you will notice a change. The way you are describing it to me sounds like it is just worn out. How many miles are on the car? 145k..... I've never replaced the suspension.....
March 27, 201313 yr Author Yeah thats a lot of miles on the original suspension I got my car at 53k... no idea if it's ever been touched.... doubt it.....
March 27, 201313 yr http://www.tirerack.com/suspension/Susptabl.jsp?autoMake=Toyota&autoModel=Camry+LE&autoYear=2003&autoModClar=
March 27, 201313 yr Author http://www.tirerack.com/suspension/Susptabl.jsp?autoMake=Toyota&autoModel=Camry+LE&autoYear=2003&autoModClar=thanks a ton for that link... last time I went to tirerack they ONLY sold tires.... didn't know they had that stuff
May 3, 201312 yr Author sooo.... updates.... finally working.... Thinking about doing the rear struts/coils first.... Any difference between H&R and Eibach??? They are within $40 of each other so no reason to quibble about that, but are the H&R better in some aspect? The Eibachs would give me a drop of F 1.4 / R 1.1 ... The H&R would be F 1.4 / R 1.3 ...... OR should I just go with stock at a total of $145 ???? These are the Eibach: http://www.amazon.com/gp/product/B000CN9VLO/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER These are the H&R: http://www.amazon.com/H-R-54683-1-Sport-Spring/dp/B00C7M2JJE Stock: Edited May 3, 201312 yr by Shogen
May 3, 201312 yr When you say drop I'm assuming you mean lower. So I guess it depends on how low that will make your car and taking account you're into car audio and could potentially put a decent amount of weight into the trunk. I mean after a 1" drop how much ground clearance do you have? Would you feel comfortable driving over a pothole? Since its your daily driver I'd say go stock but that's just my opinion
May 3, 201312 yr Author When you say drop I'm assuming you mean lower. So I guess it depends on how low that will make your car and taking account you're into car audio and could potentially put a decent amount of weight into the trunk. I mean after a 1" drop how much ground clearance do you have? Would you feel comfortable driving over a pothole? Since its your daily driver I'd say go stock but that's just my opinion yea I meant lower.... but you're right and in my shopping cart I already put the stock stuff as I was leaning towards it.. I mean come on, I drive a fcking family sedan and my family is the audio
