May 19, 201313 yr Is the sub in the trunk? Is it sealed off from the cabin? Did you check the wiring with a dmm to make sure you have the proper ohms?
May 19, 201313 yr Author Is the sub in the trunk? Is it sealed off from the cabin? Did you check the wiring with a dmm to make sure you have the proper ohms? Thanks for the quick reply. Yes - my sub is in the trunk, which is sealed off from the cabin. I've got a DMM, but how exactly would I test the wiring? Just connect the DMM to the amp? or to the speaker wire itself?
