My alt charges at 14.4
Have a batt bank, and stays above 13v whith hard bass hits.
After a while my subs loose "thump" I still have some bass I'll turn the volume down and it comes
right back. I have my gain set to 7 at 28 volts well below max output.
Brand new T1000-4ad running two P3's.
Edited by Cant Get Enough
is the amp overheating? check your connections and ground
I have hardly anything to go off of here...
Do you use the factory stereo?
Do you use any external processors?
Do you use aftermarket or a rockford gain control up front?
do you use any kind of remote gain control?
I would guess the amp is just losing voltage, thats all. Which is normal because you said it happens after a while. For example, in my vehicle, after about 80 seconds full tilt, my voltage will drop from 14.1 to 13.2 and I can hear a lost in volume. I doubt there is anything "wrong" in your case though.
Check the fuse from the front to the back batteries.
I'm also very curious as to why get a 4 channel to push your subs, especially such an expensive one.
I've been installing my own systems since 1992. PPI and Rockford were my favorites
so I've stuck with them and class ab were all we had but when class d came out with
higher wattage I tried them and thought the sound was awful muffled and woofy.
So I never used class d again until Rockford came out with class ad that was supposed
to be as clean as class ab so I swapped out my T6002 ab for the T10004-ad to
utilize th e full potential of my P3's and they were definately clean but Rockford doesn't
make a 2 channel version so I'm stuck using a 4 channel. I guess manufacturers don't think someone would ever want a clean sounding
2 channel amp with enough power going to subs
I know people will say you can't here the difference but I can and
even though you probably cant hear the audible distortion and me
having a background in studio recording there is definately a loss
in transparency "hearing through the bass"
What ohm load is the amp at?
2 ohms
amps are hooked to the back batts and they're still charging
I solved my loss of bass problem. When I was doing routine connection
cleaning I found that my ground to body from sub amp had almost pulled completely
out of the crimp connector and didn't notice it under the shrink wrap. Yeeaahhhh!!!
Just an FYI, try it with a newer amp on a sub and you most definitely will change your mind.
You do realize the "as clean as a class A/B" is just a marketing phrase, correct?  So that's all it took to cure you of your bias against class D, a marketing phrase that caught your attention?
If the frequency response, noise and the distortion of both amps is within inaudible tolerances....then the class D is every bit as "clean" as the class A/B....and there are hundreds of class D amps on the market that meet that criteria.
Studio background has nothing to do with it.
It's actually a front stage amp. Not intended for subs. Why do people use
only ab for door speakers?
ive seen people use full range class D in their front stage with success
I do believe my Class D ZED Leviathan III plays quite well and lovely if I don't say so myself.
I've got class d on my fronts and am old too. Probably as picky if not the pickiest on the site too
^This
