  • Replies 53
  • Views 14.3k
  • Stop being a moron. OP's thread doesn't at all follow the Terms & Conditions of the board he agreed to when joining. If it did, he'd have an answer. The real answer here is though that an 8" driv
  • jonbearsmt
    jonbearsmt
    lol so please share with us your "likes" of this sub...  please.    secondly buying a sub based on a Xmax figure is like buying a sports car because it has an ash tray
  • Quentin Jarrell
    Quentin Jarrell
    The sa sub has a great deal more linear excursion. A ported 8 never makes sense when you have room for a larger OD sub bc of port length. Due to the necessary port area for the given box volume an en
I'm sorry that you feel that way that I made a terrible mistake because as far as I am concerned It is a great choice. You have your likes and I have mine. They are both great subs so please keep your negative comments to yourself.
  • 3 weeks later...
There isn't a DD 8" woofer made with near the linear mechanical capacity of the SA-8 v.2 -- the DD 2508-SC I had Klippel testing has a hot mess of a CMS curve and a very odd BL curve. I am confident the 1008 and 1508 have a better suspension as they use 2" coils, though... but I wouldn't expect LF performance as good as an SA-8 v.2 from either. I haven't had a 1008 or 1508 in here for Klippel yet, though.
Stock woofer vs. stock woofer the 1508 would be better at SPL burps than an SA-8 v.2, though. Many people enjoy the "punchy" sound from a 1508 as well; but if your goal is low-end extension the SA-8 v.2 would be a better choice.
Edited by sundownz
8" subs could be beneficial when used in multiples. More cone area and more coils to apply the same amount of power versues smaller quantity of larger subs.
You are the guy that buys the two small pepperoni pizzas for three bucks more than the large even though it is 15% less food.
you are the 1 of the guys that scares away the potential new customer
with your attitude problem
Because he is trying to correct wrong information while being helpful?   ughdunno.gif
