Posted April 4, 201313 yr I'm going to be selling my rockford t1 15 but I'm going to build a new box for it. My current one is tuned to 38hz which is probably why my lows aren't to good. I want to try tuning it to 32hz unless someone has a better recommendation.This is the box I have right now - http://imageshack.us/a/img828/4849/imagesyn.jpgI want to keep the height the same, but knock the depth about 2-3inchs if possible, and my width can be bigger. I'm not very understanding of port size and how to get that tuning/and get the cubes it needs with the different size port.
April 5, 201313 yr Author Or can someone point in a direction on how to build a box. Just trying learn.
April 5, 201313 yr By doing a quick calculation if you make the 18h x 38w x 15d and make your port a total of 30" it brings you to 31.77hz before displacement. After sub displacement it will bring that up a little bit. Currently your port is 25" long to acheive 30 you naturaly would extend the 2nd port wall 5" longer. I use this calculatorhttp://torres-box-tuning-calculator.software.informer.com/ Works great.
