Posted April 5, 201312 yr website specs say they like 2.5-2.75ft^3 do they like larger than 2.75 or should i keep it there?
April 5, 201312 yr I think a 3.0ft^3 enclosure would be what you should aim for to account for the XCONs 0.17 cu.ft displacement. If you choose to double baffle or add bracing, that would lower the volume as well. In the end you should have close to the recommended size enclosure. Edited April 5, 201312 yr by azlnick
April 5, 201312 yr Author i would accommodate for displacement and port walls obviously.. im just asking if theyd like a bigger box closer to 3.5 or so?
April 5, 201312 yr i would accommodate for displacement and port walls obviously.. im just asking if theyd like a bigger box closer to 3.5 or so?No I would not go that big. SSA recommends an accurate range.
