I'm not sure it's possible to tell from just looking at that. What's your dimesions, subs, and tuning frequency? I can get you the port length if you give me that info.
Dimensions (W x H x D): 33" x 16-1/2" x 21"
1-1/4" Reinforced MDF front baffle
4.0 ft^3 slot-port tuned @ 32Hz
and 2 sa-10s
So you have a 1/2 inch baffle to go on to the 3/4 inch front? I would just put a 3/4 inch baffle on the front to make it 1.5 inch
EDITED!
I would do the double baffle 1.5" because of each baffle being .75".
Port dimesions:
15h x4w
60in2 of port area
***Port length is 33"
Box ends up being 3.75 cubes tuned to 32.5hz.
That's the best I can get it to what you want with having enough port area. If you can add on to any dimesions it would help lower tuning and gain more volume.
Edited by Bassink
i made it on google sketch and i just need the port parts so i can get the dimensions to cut everything but i dont wanna mess it up
Yea just use two .75" pieces of mdf for the double baffle. I accidently put in wrong numbers for the first time but I edited my last post and everything is correct now.
where are you getting 30 inches for the inside port?
like the walls inside that make the airflow out of the box
Edited by ImaSlacker
Check it again lol I entered it all right now.
What do you mean where am I getting it from? I add length until I get the right tuning.
The port is 33" long. You know how you see the L shape, that's what it's length is.
Edited by Bassink
well when i make the 33 inches it doesnt fit to make the L shape it goes outside of the box lol
 sorry for my noobness
The length will go in a L shape. You start from the port opening and continue to go all the way until you reach 33". Does that make sense?
I would only have the double baffle 1.5". Everything else .75".
Yea no problem
Are you just needing a design to build your own box? Or needing that exact one?
