Posted April 6, 201313 yr just need to know if anyone could tell me the port lengths inside this box http://www.ebay.com/itm/4-0-FT-3-TUNED-32Hz-SLOT-VENTED-CUSTOM-MDF-SUB-ENCLOSURE-2-10-INCH-SUBS-/400326246337 id rather make the box instead of buying it lol, but if anyone could be so kind to help out thatd be great
April 6, 201313 yr I'm not sure it's possible to tell from just looking at that. What's your dimesions, subs, and tuning frequency? I can get you the port length if you give me that info.
April 6, 201313 yr Author Dimensions (W x H x D): 33" x 16-1/2" x 21"1-1/4" Reinforced MDF front baffle4.0 ft^3 slot-port tuned @ 32Hzand 2 sa-10s
April 6, 201313 yr So you have a 1/2 inch baffle to go on to the 3/4 inch front? I would just put a 3/4 inch baffle on the front to make it 1.5 inch
April 6, 201313 yr EDITED!I would do the double baffle 1.5" because of each baffle being .75".Port dimesions:15h x4w60in2 of port area***Port length is 33"Box ends up being 3.75 cubes tuned to 32.5hz.That's the best I can get it to what you want with having enough port area. If you can add on to any dimesions it would help lower tuning and gain more volume. Edited April 6, 201313 yr by Bassink
April 6, 201313 yr Author i made it on google sketch and i just need the port parts so i can get the dimensions to cut everything but i dont wanna mess it up
April 6, 201313 yr Yea just use two .75" pieces of mdf for the double baffle. I accidently put in wrong numbers for the first time but I edited my last post and everything is correct now.
April 6, 201313 yr Author where are you getting 30 inches for the inside port? like the walls inside that make the airflow out of the box Edited April 6, 201313 yr by ImaSlacker
April 6, 201313 yr Check it again lol I entered it all right now. What do you mean where am I getting it from? I add length until I get the right tuning.
April 6, 201313 yr The port is 33" long. You know how you see the L shape, that's what it's length is. Edited April 6, 201313 yr by Bassink
April 6, 201313 yr Author well when i make the 33 inches it doesnt fit to make the L shape it goes outside of the box lol sorry for my noobness
April 6, 201313 yr The length will go in a L shape. You start from the port opening and continue to go all the way until you reach 33". Does that make sense?
