Posted April 8, 201312 yr Vehicle : 2002 Toyota Avalon XLSLocation in the vehicle: Trunk with rear armrest access portSpace available (Length x Width x Height): 22"x42"x16"Subwoofer make and model: SSA XCON 12 D1Number of Subwoofers: 1 for now.Type of Port (Kerfed, Slot, Aero, etc.): Kerfed would be optimal, Slot if not kerf.What type of music do you like?: Electronic, Drum n Bass, Classic Rock, Alternative, Rap, Hip-Hop, R&B.Is your goal SPL or Everyday Music?: Everyday Music geared towards SQTuning Freq (Hz): 28-30 or soVolume : 2.5-3.0Questions: 1. I plan on only giving about 600-1200w by a Crescendo BC2000D, should I have the volume of the box be closer to 3.0 to maximize efficiency?2. As far as tuning goes, I would love to enjoy the lows and compliment my Image Dynamics CXS62v2 front stage. Is @28hz low enough? Should I port even a bit higher to make sure I have the SPL I am expecting from the XCON?3. I plan on doing double baffle and flush-mounting the sub, do I need any bracing? How does kerfing compare to slot in terms of output, SQ, and is it worth the effort? I'd love to hear your in-depth explanations so I can know more about fabrication, box building, and audio in general. Thanks in advance guys!
April 8, 201312 yr I'd build the box closest to the highest optimal that ssa recommends. If I were you I would tune a little higher like around 32hz. The music you listen to really doesn't go all that low. I listen to decaf and I'm tuned to 32hz and it gets it all. I would probably put some bracing in there since it's a really wide box.
April 8, 201312 yr Author I've seen people suggesting to use threaded rods for internal bracing, how would I do this? Still wondering if kerfing is worth it.
